货架上报告的温度传感器"1"的严重超温故障
适用于
- DS212C
- DS224C
- DS460C
- DS4246
- DS4486
问题
EMS
- 系统报告了以下磁盘架警告:
Critical over temperature failure for temperature sensor "1". Current temperature: "123" C ("253" F).DataGrovePG4N1: dsa_worker4: ses.status.temperatureError:error]: DS4246 (S/N SHJSG1818#######) shelf 21 on channel 0a temperature error for Temperature sensor 1: critical status; overtemperature failure. Current temperature: 43 C (109 F). This module is on the front of the shelf on the left, on the OPS panel.- 检查传感器信息时,可以在 CLI 上看到以下内容:
- ::> system node run -node
-command storage show fault -v
Enclosure Status: criticalChannel: 0aShelf: 12Shelf Type: DS212-12Product Serial Number: xxxxxxxxxxxxxxxModule Type: IOM12Temperature Sensors:Element Status Status Bytes Status Descriptions1: CRITICAL 02,00,8F,0C OT WARNING, OT FAILUREAutoSupport 日志
- STORAGE SHELF.XML
ERROR:Temperature reported by temperature sensor "1" exceeds the specifications for the disk shelf or its components.
- ENVIRONMENT
Channel: 0d
Shelf: 20
Temperature Sensor installed element list: 1, 2, 3, 4, 9, 10, 11, 12; with error: none
Shelf temperatures by element:
[1] Unavailable★
[2] 32 C (89 F) Normal temperature range
[3] 32 C (89 F) Normal temperature range
[4] 41 C (105 F) Normal temperature range
