跳转到主内容
架子电源上检测到冷却风扇错误
248
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
所有磁盘架
问题描述
  • PSU 警告指示灯呈琥珀色。
  • 系统生成了一条 AutoSupport (ASUP) 警报,错误信息为 SHELF COOLING UNIT FAILED
    EMS
    [node-01:dsa_worker1:ses.status.fanWarning:notice]: DS224-12 (S/N xxxxxxxxxxxx) shelf 24 on channel 0b cooling fan warning for Cooling element 1: not installed. This module is on the rear of the shelf on the lower left power supply.
    [node-01:dsa_worker1:callhome.shlf.fan.warn:error]: Callhome for SHELF COOLING UNIT FAILED
    [node-01:dsa_worker1:ses.status.fanWarning:notice]: DS224-12 (S/N xxxxxxxxxxxx) shelf 24 on channel 0b cooling fan warning for Cooling element 2: not installed.
    [node-01:dsa_worker1:ses.status.temperatureWarning:alert]: DS224-12 (S/N xxxxxxxxxxxx) shelf 24 on channel 0b temperature warning for Temperature sensor 6: not installed.
    [node-01:dsa_worker1:ses.status.temperatureWarning:alert]: DS224-12 (S/N xxxxxxxxxxxx) shelf 24 on channel 0b temperature warning for Temperature sensor 7: not installed.
    Additional sysconfig output indicated:
    环境
    Cooling Units by element:
    [1] Unavailable
    [2] Unavailable
    Shelf temperatures by element:
    [6] Unavailable
    [7] Unavailable
    Temperature thresholds by element:
    [6] High critical: Unavailable; high warning: Unavailable
    Low critical:  Unavailable; low warning:  Unavailable
    [7] High critical: Unavailable; high warning: Unavailable
  • storage shelf show -instance 命令显示以下错误。
::> storage shelf show -shelf-id 24 -instance
      Shelf Name: 4.24
       Stack ID: 4
       Shelf ID: 24
       Shelf UID: 50:0a:09:80:08:40:50:40
     Serial Number: SHJSGxxxxxxxxxx
      Module Type: IOM6
         Model: DS4246
     Shelf Vendor: NETAPP
      Disk Count: 24
    Connection Type: SAS
      Shelf State: Online
        Status: Critical
Fan "2" is running below normal RPM threshold. Fan is located in the rear of the shelf on the upper left power supply.
New to NetApp?
