跳转到主内容
控制器温度传感器 MemoryX_Hot 报告已断言
336
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • ONTAP 9
  • AFF 系统
  • FAS 系统
问题
  • 控制器故障 LED 亮起
  • 来自SP-LATEST-IPMI 日志的传感器报告为 Asserted
    • Memory_Hot
    • Memory0_Hot
    •  Memory1_Hot
/usr/local/bin/ipmi sensors
Sensor Name    | Current   | Unit    | Status   | LCR    | LNC    | UNC    | UCR
Memory0_Hot    | 0x0     | discrete  | Deasserted | na     | na     | na     | na
CPU1_Error    | 0x0     | discrete  | Deasserted | na     | na     | na     | na
CPU1_Therm_Trip  | 0x0     | discrete  | Deasserted | na     | na     | na     | na
CPU1_Hot     | 0x0     | discrete  | Deasserted | na     | na     | na     | na
Memory1_Hot    | 0x0     | discrete  | Asserted  | na     | na     | na     | na
PCH_Hot      | 0x0     | discrete  | Deasserted | na     | na     | na     | na
HSAM OS(0x5):cmd(1) FLD(controller-b):fault(Temperature Sensor 9 Fault)
hsamcmd --fault-show-all
tag  origin  fld                    fault reason                   count  time
2   0x5    /chassis-1/controller-b          Temperature Sensor 9 Fault            1
::> system environment sensors show -state !normal
Node Sensor State Value/Units Crit-Low Warn-Low Warn-Hi Crit-Hi
node1
Memory1 Hot  fault HOT
  • SP-reboot 不清除此传感器状态
New to NetApp?
