机箱电源已降级:PSU 风扇速度严重偏低
适用于
- 电源单元 (PSU)
- FAS 系统
- AFF 系统
问题
- EMS 报告"
Chassis power supply is degraded: PSU Fan Speed is Critical Low"。
[Node1:monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 has failed
[Node1:monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 DC has failed
[Node1:callhome.chassis.ps.degraded:error]: Call home for CHASSIS POWER SUPPLY DEGRADED: PS 1
[Node1:monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Fan1 Speed is Critical Low (2600 RPM)
monitor.globalStatus.critical: Power Supply Status Critical: PSU2. Chassis temperature is too low
environment status显示了受影响的 PSU 上的 critlow。
PSU1 Fault FAULT
PSU1 DC OK FAULT
PSU1 ON ON
PSU1 Input OK OK
PSU1 Fan2 Fault OK
PSU1 Fan2 Speed normal 7500 RPM 4500 RPM 4600 RPM -- --
PSU1 Fan1 Fault OK
PSU1 Fan1 Speed critlow 2800 RPM 4500 RPM 4600 RPM -- --
PSU1 Curr normal 3790 mA -- -- -- --
PSU1 Temp normal 25 C 0 C 5 C 50 C 60 C
