跳转到主内容
由于环境温度高导致的机箱温度过高警报
76
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • AFF / ASA / AFX / FAS
  • ONTAP 9
问题
  • 在集群中的两个节点上报告了以下 EMS 和 AutoSupport 消息:
[node1:env_mgr:monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: LED2 Temp is warning high (38C).
[node1:env_mgr:monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: LED1 Temp is warning high (38C).
[node1:monitor:monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too high..
[node1:env_mgr:callhome.chassis.hitemp:error]: Callhome for CHASSIS OVER TEMPERATURE
[node2:env_mgr:monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: LED2 Temp is warning high (38C).
[node2:env_mgr:monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: LED1 Temp is warning high (38C).
[node2:monitor:monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too high..
[node2:env_mgr:callhome.chassis.hitemp:error]: Callhome for CHASSIS OVER TEMPERATURE
  • PLATFORM-SENSORS.XML:
LED1 Temp thermal warn-high 38C
LED2 Temp thermal warn-high 38C
New to NetApp?
