因机箱风扇FRU出现故障而致电主页
适用场景
- FAS/AFA系统
- ONTAP 9
问题描述
- 事件日志中报告了以下错误:
[Node-02: env_mgr: monitor.chassisFan.stop:debug]: Chassis fan contains at least one stopped fan: Fan1 (0 RPM)
[Node-02: env_mgr: callhome.c.fan.fru.fault:debug]: Call home for CHASSIS FAN FRU FAILED: Fan1
或
[Node-04: env_mgr: monitor.chassisFan.stop:debug]: Chassis fan contains at least one stopped fan: Sysfan4_F2_Speed (failed)
[Node-04: env_mgr: callhome.c.fan.fru.fault:debug]: Call home for CHASSIS FAN FRU FAILED: Sysfan4_F2_Speed
- 一个或两个风扇的传感器状态位于
"BAD"
SP传感器部分:
Fan2 State discrete normal normal GOOD
Fan1 State discrete fault normal BAD
Sensor name | reading | unit | status| lnr | lcr | lnc | unc | ucr | unr
Sysfan4_F1_Speed | 9204.000 | RPM | ok | 0.000 | 936.000 | 2964.000 | 33072.000 | 34008.000 | 34944.000
Sysfan4_F2_Speed | 0.000 | RPM | nr | 0.000 | 936.000 | 2964.000 | 33072.000 | 34008.000 | 34944.000
