针对 FAS27xx 和 AFF A220 的电池(不存在)严重警报回传
适用于
- AFF A220
- AFF C190
- FAS2750
- FAS2720
问题描述
- 启动时的错误报告:
WARNING: The battery is unfit to retain data during a power
outage. This is likely because the battery is
discharged but could be due to other temporary conditions.
When the battery is ready, the boot process will
complete and services will be engaged.
To override this delay, press 'c' followed by 'Enter
- 在重新启动之前从 EMS 看到以下错误
Mar 24 06:49:59 [node:callhome.battery.failure:EMERGENCY]: Call home for BATTERY (not present) CRITICAL.
Mar 24 06:51:00 [node:nvmem.battery.notPresent:ALERT]: The NVMEM battery is not present. To prevent data loss, the system will shut down in 5 minutes.
- 从 BMC 运行"system battery show"报告没有电池
BMC-01> system battery show
Battery pack is absent.
- 系统无法识别电池组:
::> system node environment sensors show
Bat_Temp | na | degrees C | na | 0.000 | 5.000 | 56.000 | 60.000
Bat_Volt | na | Volts | na | 5.500 | 5.600 | 8.500 | 8.600
Bat_Curr | na | Amps | na | na | na | 1.520 | 1.800
Bat_Rem_Cap | na | Amps * hour | na | na | na | na | na
Bat_Full_Cap | na | Amps * hour | na | na | na | na | na
Bat_Charge_Curr | na | Amps | na | na | na | 2.400 | 2.900
Bat_Charge_Volt | na | Volts | na | na | na | 8.900 | 9.000
Bat_Design_Cap | na | Amps * hour | na | na | na | na | na
Bat_Initial_Fcc | na | Amps * hour | na | na | na | na | na
Bat_Average_Temp | na | degrees C | na | na | na | na | na
Bat_Rem_Cap_off | na | Amps * hour | na | na | na | na | na
Bat_Dstg_Cycles | na | cycles | na | 2.000 | 5.000 | na | na
Bat_Power_Fault | 0x0 | discrete | Asserted | na | na | na | na
Bat_Dsg_FET_Flt | na | discrete | na | na | na | na | na
Bat_Chg_FET_Flt | na | discrete | na | na | na | na | na
Bat_Pack_Invalid | na | discrete | na | na | na | na | na
Bat_Cycle_Cnt | na | cycles | na | na | na | na | na
Bat_Lrn_Active | na | discrete | na | na | na | na | na
- 将 BMC 升级到最新版本
- 如果 BMC 使用最新版本,请重新拔插 NVRAM 电池以强制重新初始化
