跳转到主内容
请致电主页了解关键电池(不存在) FAS27xx 和 AFF A220
12
Visibility:
Votes:
0
Category:
aff-series<a>2008704035</a>
Specialty:
HW
Last Updated:
适用场景
  • AFF A220
  • AFF C190
  • FAS2750
  • FAS2720
问题描述
  • 启动时的错误报告:
WARNING: The battery is unfit to retain data during a power outage. This is likely because the battery is discharged but could be due to other temporary conditions. When the battery is ready, the boot process will complete and services will be engaged. To override this delay, press 'c' followed by 'Enter
Mar 24 06:49:59 [node:callhome.battery.failure:EMERGENCY]: Call home for BATTERY (not present) CRITICAL.
Mar 24 06:51:00 [node:nvmem.battery.notPresent:ALERT]: The NVMEM battery is not present. To prevent data loss, the system will shut down in 5 minutes.
  • 系统无法识别电池组:
::> system node environment sensors show
Bat_Temp      | na     | degrees C  | na      | 0.000    | 5.000    | 56.000   | 60.000
Bat_Volt      | na     | Volts    | na      | 5.500    | 5.600    | 8.500    | 8.600
Bat_Curr      | na     | Amps     | na      | na     | na     | 1.520    | 1.800
Bat_Rem_Cap    | na     | Amps * hour | na      | na     | na     | na     | na
Bat_Full_Cap    | na     | Amps * hour | na      | na     | na     | na     | na
Bat_Charge_Curr  | na     | Amps     | na      | na     | na     | 2.400    | 2.900
Bat_Charge_Volt  | na     | Volts    | na      | na     | na     | 8.900    | 9.000
Bat_Design_Cap   | na     | Amps * hour | na      | na     | na     | na     | na
Bat_Initial_Fcc  | na     | Amps * hour | na      | na     | na     | na     | na
Bat_Average_Temp | na     | degrees C  | na      | na     | na     | na     | na
Bat_Rem_Cap_off  | na     | Amps * hour | na      | na     | na     | na     | na
Bat_Dstg_Cycles  | na     | cycles    | na      | 2.000    | 5.000    | na     | na
Bat_Power_Fault  | 0x0     | discrete   | Asserted   | na     | na     | na     | na
Bat_Dsg_FET_Flt  | na     | discrete   | na      | na     | na     | na     | na
Bat_Chg_FET_Flt  | na     | discrete   | na      | na     | na     | na     | na
Bat_Pack_Invalid | na     | discrete   | na      | na     | na     | na     | na
Bat_Cycle_Cnt   | na     | cycles    | na      | na     | na     | na     | na
Bat_Lrn_Active   | na     | discrete   | na      | na     | na     | na     | na
New to NetApp?
