跳转到主内容
连接到 SAS 端口 x 的电缆在降级模式下工作
100
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • ONTAP 9
  • SAS 存储架
  • 系统采用多路径 HA 布线
问题描述
  • ONTAP 事件消息系统示例
[sas.cable.degraded:warning]: Cable attached to SAS port "0b" is functioning in a degraded mode
  • ONTAP 事件日志显示输出示例
::> event log show -event sas.cable*
Time Node    Severity Event
...  node_name ERROR   sas.cable.degraded: Cable attached to SAS port "0a" is functioning in a degraded
  • ONTAP 系统运行状况降级示例
::> system health subsystem show
Subsystem      Health
SAS-connect     degraded
Environment     ok
SAS-connect_Cluster ok
13 entries were displayed.
  • 从 ONTAP CLI sysconfig -a 输出检查时,某些 PHY 的速度降低/禁用/速率未知。示例
::> system node run -node <node_name> -command sysconfig -a
slot 0: SAS Host Adapter 0a (PMC-Sierra PM8072 rev. C, SAS, <UP>)
   Firmware rev:     03.08.09.00
   Base WWN:       5:00a098:00e1428:a4
   Temperature:     Not Available
   Phy State:      [8] Enabled, 12.0 Gb/s
                  [9] Enabled, 6.0 Gb/s
                  [10] Enabled, 6.0 Gb/s
                  [11] Enabled, 12.0 Gb/s
   Base WWN:       5:00a098:00f46d8:30
   Phy State:      [0] Disabled
                  [1] Disabled
                  [2] Enabled, Rate unknown
                  [3] Enabled, 12.0 Gb/s
  • 使用新的 SAS 电缆问题仍然存在
  • 连接该 SAS 电缆的新磁盘架 IOM 模块问题仍然存在
New to NetApp?
