跳转到主内容
出现 "Chassis power degraded : Power Supply Status Critical " 警告消息
654
Visibility:
Votes:
2
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
FAS8060
问题
中显示了以下消息 EMS-LOG-FILE.GZ
Jan 03 05:47:28 JST [node_name: sp_config_main: spmgmt.driver.timeout:warning]: The software driver for the Service Processor (SP) detected a problem: Unable to update SP network information at this time.
Jan 03 05:50:31 JST [node_name: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Temperature is Critical Low (0 C)
Jan 03 05:50:31 JST [node_name: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Fan1 Speed is Critical Low (2100 RPM)
Jan 03 05:50:31 JST [node_name: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Fan2 Speed is Critical Low (0 RPM)
Jan 03 05:50:34 JST [node_name: power_low_monitor: monitor.chassisPower.degraded:warning]: Chassis power is degraded: Power Supply Status Critical.
Jan 03 05:50:34 JST [node_name: power_low_monitor: callhome.chassis.power:error]: Call home for CHASSIS POWER DEGRADED: Power Supply Status Critical.
但 PSU1 Temp 和 PSU1 Fan Speed 在中是正常的 ENVIRONMENT
Sensor Name              State          Current    Critical     Warning     Warning    Critical
                                        Reading       Low         Low         High       High
PSU1 need replacement                       NO
PSU1 State                                GOOD
PSU1 Temp                normal            17 C         0 C         5 C        50 C        60 C
PSU1 Fan1 Speed          normal         10700 RPM    4500 RPM    4600 RPM      --          --
PSU1 Fan2 Speed          normal          9600 RPM    4500 RPM    4600 RPM      --          --
New to NetApp?
