跳转到主内容
更换后, Sysconfig 中缺少 FAS9000 , AFF A700 和 AFF A900 上的适配器卡
13
Visibility:
Internal
Votes:
0
Category:
ontap-9
Specialty:
hw<a>FSE</a>
Last Updated:
适用场景
  • ONTAP 9
  • FAS9000
  • AFF A700
  • AFF A900
  • FRU 更换( NIC , SAS 或 FC 适配器)
问题描述
更换适配器卡(例如 NIC , SAS 或 FC 适配器)后, ONTAP 无法识别该卡。  它不再显示为系统中存在。
  • 更换适配器卡之前的 AutoSupport sysconfig-ac 输出(插槽 1 存在):
sysconfig: slot 1 OK: X91440A: 40G high performance
sysconfig: slot 2 OK: X91143A: Qlogic EP8324 Quad-Port 16Gb FC/10GbE PCIe CNA
sysconfig: slot 3 OK: X92071A: PMC PM8072; PCI-E quad-port SAS (PM8072)
sysconfig: slot 4 OK: X91440A: 40G high performance
sysconfig: slot 5 OK: X92071A: PMC PM8072; PCI-E quad-port SAS (PM8072)
sysconfig: slot 6 OK: X93140A: NetApp NVRAM10
sysconfig: slot 6-1 OK: X9172A: Flash Cache, 4.0TB NVMe SSD
sysconfig: slot 6-2 OK: X9172A: Flash Cache, 4.0TB NVMe SSD
sysconfig: slot 7 OK: X92071A: PMC PM8072; PCI-E quad-port SAS (PM8072)
sysconfig: slot 8 OK: X91440A: 40G high performance
sysconfig: slot 9 OK: X92071A: PMC PM8072; PCI-E quad-port SAS (PM8072)
sysconfig: slot 10 OK: X91143A: Qlogic EP8324 Quad-Port 16Gb FC/10GbE PCIe CNA
sysconfig: slot 11 OK: X92071A: PMC PM8072; PCI-E quad-port SAS (PM8072)
sysconfig: No shelf configuration errors detected.
sysconfig: There are no configuration errors.
  • 更换适配器卡后的 AutoSupport sysconfig-ac 输出(插槽 1 缺失):
New to NetApp?
This is an internal KB article and its content should not be copy/pasted and shared with people outside of NetApp. Always seek Duty Manager authentication of caller for password reset requests. If you need further assistance post a question in Knowledge Xchange
