跳转到主内容
由于SCSI刀片式服务器脱机、ANDU已暂停、无法执行接管
114
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
适用场景
  • ONTAP 9
  • AF-A700
问题描述
  • 由于SCSI 刀片式服务器脱机、ANDU已暂停、无法执行接管。
Cluster::*> storage failover show
 (storage failover show)
               Takeover
Node       Partner     Possible State Description
node-1
                false   Connected to node-2,
        node-2           Partial giveback, Takeover is not
                             possible: The version of software
                    running on each node of the SFO pair
                    is incompatible, NVRAM log not
                    synchronized
node-2
                false   Connected to  node-1.
        node-1              Waiting for cluster applications to come online
                    on the local node. Offline
                    applications: scsi blade. Takeover
                    is not possible: The version of
                    software running on each node of the
                    SFO pair is incompatible, NVRAM log
                    not synchronized
  • 在节点2上完成ONTAP升级后、系统会使节点2上的FC适配器脱机。
     slot 2: Fibre Channel Target Host Adapter 2a
         (Emulex LPe32000 (LPe32004) rev. 0, <OFFLINED BY SYSTEM>)
         Firmware rev:    0.0.0.0
         Host Port Addr:   000000
         FC Nodename:     50:0a:09:80:xx:xx:xx:xx (500a0980xxxxxxxx)
         FC Portname:     50:0a:09:85:xx:xx:xx:xx (500a0985xxxxxxxx)
         Connection:     No link
         Switch Port:     Unknown
     slot 2: Fibre Channel Target Host Adapter 2b
         FC Portname:     50:0a:09:86:xx:xx:xx:xx (500a0986xxxxxxxx)
         Connection:     No link
New to NetApp?
