跳转到主内容
AFF-C250 HA组通知(机箱电源关闭:PS 1)错误
14
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw<a>电源故障</a><a>AFF C250、AFF C400、AFF C800 ( SEGundo )</a><a>2009636402</a>
Last Updated:
适用场景
  • ONTAP 9
  • AF-C250
问题描述
  • 中的错误 EMS-LOG-FILE.gmz ,但最终会 清除
[?]  Wed Jul 05 04:14:49 +0100 [node-4: env_mgr: monitor.chassisPowerSupply.off:debug]: Chassis power supply 1 off.
[?]  Wed Jul 05 04:15:00 +0100 [node-4: monitor: monitor.globalStatus.critical:debug]: Power Supply Status Critical: PSU1. Chassis temperature is too low..
[?]  Wed Jul 05 04:22:26 +0100 [node-4: wafl_exempt05: wafl.vol.snap_create.done:debug]: params: {'type': 'Volume', 'owner': '', 'vol': 'repo', 'app': '', 'volident': '@vserver:8dfcab95-ff03-11ed-b99e-d039ea53839c', 'run_time': '25339'}
[?]  Wed Jul 05 04:30:09 +0100 [node-4: env_mgr: monitor.chassisTemperature.ok:debug]: Chassis temperature is ok.
[?]  Wed Jul 05 04:30:39 +0100 [node-4: env_mgr: monitor.chassisTemperature.cool:debug]: Chassis temperature is too cool: PSU1 Hot is critical low (0 C).
[?]  Wed Jul 05 04:30:49 +0100 [node-4: env_mgr: monitor.chassisPowerSupply.degraded:debug]: Chassis power supply 1 is degraded: PSU1 In Fault is FAULT
[?]  Wed Jul 05 04:31:00 +0100 [node-4: monitor: monitor.globalStatus.critical:debug]: Power Supply Status Critical: PSU1.
[?]  Wed Jul 05 04:31:09 +0100 [node-4: env_mgr: monitor.chassisPowerSupply.degraded:debug]: Chassis power supply 1 is degraded: PSU1 Hot is Critical Low (0 C)
[?]  Wed Jul 05 04:31:19 +0100 [node-4: env_mgr: monitor.chassisPowerSupply.degraded:debug]: Chassis power supply 1 is degraded: PSU1 Fan is Critical Low (0 RPM)
[?]  Wed Jul 05 04:31:19 +0100 [node-4: env_mgr: monitor.chassisPowerSupply.off:debug]: Chassis power supply 1 off.
[?]  Wed Jul 05 04:32:00 +0100 [node-4: monitor: monitor.globalStatus.critical:debug]: Power Supply Status Critical: PSU1. Chassis temperature is too low..
[?]  Wed Jul 05 04:33:09 +0100 [node-4: env_mgr: monitor.chassisPowerSupply.ok:debug]: Chassis power supply 1 is OK.
[?]  Wed Jul 05 04:33:11 +0100 [node-4: power_low_monitor: monitor.chassisPowerSupplies.ok:debug]: Chassis power supplies OK.
[?]  Wed Jul 05 04:34:00 +0100 [node-4: monitor: monitor.globalStatus.ok:debug]: The system's global status is normal.
[?]  Wed Jul 05 04:34:09 +0100 [node-4: env_mgr: callhome.chassis.ps.ok:debug]: Call home for CHASSIS POWER SUPPLY OK: PS 1
New to NetApp?
