Storage shelf show -instance 显示空白输出
适用于
- AFF A250
- AFF C250
- AFF A800
- AFF C30
- AFF A70
- FAS 500f
- NS224 NSM8E
- NS224 NSM16E
- FS4483 PSM3E
问题
对于内部 NVMe 盘架(NS224 NSM8E/NS224 NSM16E/FS4483 PSM3E), storage shelf show -instance 命令对于电源、风扇和温度等项目显示"-",无法获取信息。
::> storage shelf show -instance
Shelf Name: 1.0 Stack ID: 1 Shelf ID: 0 Shelf UID: **** Serial Number: **** Module Type: NSM8E Model: NS224NSM8E Shelf Vendor: NETAPP Disk Count: 24 Connection Type: NVMe Shelf State: Online Status: Normal
Modules: Module is Monitor Is Reporting FW Update Latest Swap Operational Module ID Part No. ES Serial No. is Active Master Element Progress FW Rev. FW Rev. Count Status Location--- ------------ --------------- --------- ------ --------- ------------- ------- ------- ----- ----------- -------------- A 111-04585+A6 7921130*** true true true not-available 0120 - 0 normal rear of the shelf at the top, on shelf module (A) B 111-04585+A6 7921130*** true false false not-available 0120 - 0 normal rear of the shelf at the bottom, on shelf module (B)
Paths: SpeedController Initiator Initiator Side Switch Port Target Side Switch Port Target Port TPGN Gb/s I/O KB/s IOPS------------------ --------- -------------------------- -------------------------- ------------------ ------ ----- -------- -------aff250-rtp-4a 0s - 0s ef000000abef0000 40 0 0 0aff250-rtp-4b 0s - 0s ef000000abef0000 40 0 0 0
Power Supply Units: Crest Power Reset PSU Operational ID Type Part# Serial# Power Rating Factor Drawn Capable Enabled Firmware Status PSU Location--- ---- ------------ --------------- -------------- ------ ------- ------- ------- -------- ---------------- ------------------------ - - - - - - - - - - - -
Voltage Sensors: Voltage Operational ID (V) Status Sensor Location--- ------- ---------------------- ------------------------ - - - -
Current Sensors: Current Operational ID (mA) Status Sensor Location--- ------- ---------------------- ------------------------ - - - -
Fans: Speed Operational ID (RPM) Status Fan Location--- ------ ----------------------- ---------------------- - - - -
Temperature: -- Thresholds °C -- Temp Is Low Low High High Operational ID °C Ambient Crit Warn Crit Warn Status Sensor Location--- ---- ------- ---- ---- ---- ---- ------------------ -------------------------------- - - - - - - - - -
DIMM: ID Mod Type Size Speed Status Location--- --- ---- ---- ------- ------------ ------------------------------- - - - - - - -
Boot Devices: ID Mod Type Size Status--- --- ---------- ------ ------------ - - - - -
Coin Battery: Voltage ID Mod (mV) Status--- --- ------- ------------ - - - -
SAS Ports: -- Port Speeds Gb/s -- Power PortPhy # IOM Port Type WWPN Operational Negotiated Status Status----- --- --------- ----------------- ----------- ---------- ------ ----------- - - - - - - - -
FC Ports: Port ID Port Type Status--- --------- ----------- - - -
PCIe Ports: -- Speed (Gb/s) --Mod ID Type Bay Negotiated Maximum Status--- --- -------- --- ---------- ------- ------------------ A 0 disk 0 8.0 8.0 ok A 1 disk 1 8.0 8.0 ok A 2 disk 2 8.0 8.0 ok
