跳转到主内容
无法通过 Web 图形用户界面为默认集群映射 E 系列 SANtricity
68
Visibility:
Internal
Votes:
0
Category:
e-series-systems
Specialty:
esg<a>2008740753</a>
Last Updated:
适用场景
NetApp SANtricity OS 11.60.2R1
问题描述
由于错误消息建议在分配卷之前禁用数据保证,无法分配卷。
Disable Data Assurance to Assign Volume
The default cluster has at least one host port that is connected to the storage array through an I/O interface that is NOT data assurance (DA) capable. However, The following volumes have data assurance (DA) enabled. If you want to assign these volumes to default cluster, the DA capability must be disabled on the Volumes.
Important: disabling data Assurance Protection is an irreversible action. Once disabled, you cannot re-enable it.
New to NetApp?
This is an internal KB article and its content should not be copy/pasted and shared with people outside of NetApp. Always seek Duty Manager authentication of caller for password reset requests. If you need further assistance post a question in Knowledge Xchange
