跳转到主内容
无法配置两个网格之间的跨网格复制
23
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
适用于
  • StorageGRID 11.7 或更早版本
  • CGR (跨网格复制)
问题描述
无法建立两个 GRID 之间的 CGR 设置。无法批准网格联合连接,导致两个站点的 HTTP 500 errors 和 VIP 之间的路由失败
错误日志
127.0.0.1--[02/Jul/2025:10:01:24+0000] "POST /grid-federation/.../approve HTTP/1.1" 500 65 "-""Faraday v1.1.0"
2025/07/02 10:01:21 [error] connect() failed (113: No route to host) while connecting to upstream...
1.管理节点 - 内部服务器和证书错误
Jul  2 09:51:22 <Node_Name> NMS: |2025-07-02T09:51:22.474| ERROR   Unable to perform a Grid Federation connectivity check from <Source_IP> to <Destination_IP>
Jul  2 09:51:22 <Node_Name> NMS: |2025-07-02T09:51:22.474| ERROR  Internal server error. The server encountered an error and could not complete your request. Try again. If the problem persists, contact support. Internal Server Error (MgmtApi::LocalizedRuntimeError)
Jul  2 09:59:30 <Node_Name> NMS: |2025-07-02T09:59:30.327| ERROR  Connection test failed for connection <ID>
Jul  2 09:59:30 <Node_Name> NMS: |2025-07-02T09:59:30.327| ERROR  Validation failed. No certificate exists on the destination grid. You must upload the verification file on the destination grid before you can test the connection. (MgmtApi::LocalizedValidationError)
2.管理节点 - 连接超时和 DNS 问题
2025/07/02 09:53:05 [error] <ID>: *<Node_ID>upstream timed out (110: Connection timed out) while connecting to upstream, client: 127.0.0.1, server: _, request: "DELETE /grid-federation/<ID>/mgmt-api/grid-federation-connections/<ID> HTTP/1.1", upstream: "https://<IP>/grid-federation/<ID>/mgmt-api/grid-federation-connections/<ID>", host: "localhost:9999"
2025/07/02 09:53:10 [error] 1623554#1623554: *<Node_ID> [lua] grid_federation_balancer.lua:144: on_balance_phase(): DNS servers cannot resolve this domain name or Nginx cannot connect to any targets, exit while connecting to upstream, client: 127.0.0.1, server: _, request: "DELETE /grid-federation/<ID>/mgmt-api/grid-federation-connections/<ID> HTTP/1.1", upstream: "https://<IP>/grid-federation/<ID>/mgmt-api/grid-federation-connections/<ID>", host: "localhost:9999"
3.对等管理节点 - 证书和路由错误
来自合作伙伴管理节点的日志显示证书不匹配和路由问题。
2025/07/02 09:50:19 [error] 1129487#1129487: *13309782 upstream SSL certificate does not match "<IP>" while SSL handshaking to upstream, client: 127.0.0.1, server: _, request: "POST /grid-federation/<ID>/mgmt-api/grid-federation-connections/<ID>/approve HTTP/1.1", upstream: "https://<IP>/grid-federation/<ID>/mgmt-api/grid-federation-connections/<ID>/approve", host: "localhost:9999"
2025/07/02 10:12:10 [error] 1173090#1173090: *13317988 connect() failed (113: No route to host) while connecting to upstream, client: 127.0.0.1, server: _, request: "POST /grid-federation/<IP>/mgmt-api/grid-federation-connections/<IP>/approve HTTP/1.1", upstream: "https://<IP>/grid-federation/dca8f799-7759-446a-a696-a0e5710740b1/mgmt-api/grid-federation-connections/dca8f799-7759-446a-a696-a0e5710740b1/approve", host: "localhost:9999"
New to NetApp?
