跳转到主内容
在网关节点上安装 StorageGRID 热修补程序失败,并显示 "Error : e : sub-process /usr/bin/dpkg Returated an error code"
15
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
适用于
  • StorageGRID 11.3.0.x 热修补程序安装
  • 具有高可用性( HA )配置的网关节点。
问题
  • 应用 StorageGRID 修补程序时,网关节点上的安装将失败,并且 StorageGRID 管理界面( GMI )中返回以下错误:
Error: E: Sub-process /usr/bin/dpkg returned an error code (1)
  • /var/local/log/gdu-server.log 可以在主管理节点上的中找到以下错误消息堆栈:
Preparing to unpack .../keepalived-bycastify_11.3.0.8-20200812.0857.49736e1_all.deb ...                    keepalived is running
dpkg: warning: subprocess old pre-removal script returned error exit status 1
dpkg: trying script from the new package instead ...
dpkg: error processing archive /var/local/hotfix-tmp-183183/hotfix/./keepalived-bycastify_11.3.0.8-20200812.0857.49736e1_all.deb (--unpack):
 subprocess new pre-removal script returned error exit status 1
Preparing to unpack .../nginx-gw_11.3.0.8-20200812.0857.49736e1_amd64.deb ...
Unpacking nginx-gw (11.3.0.8-20200812.0857.49736e1) over (11.3.0-20191001.0017.4b56d62) ...
Preparing to unpack .../sudo_1.8.19p1-2.1+deb9u2_amd64.deb ...
Unpacking sudo (1.8.19p1-2.1+deb9u2) over (1.8.19p1-2.1) ...
Preparing to unpack .../tcpdump_4.9.3-1~deb9u1_amd64.deb ...
Unpacking tcpdump (4.9.3-1~deb9u1) over (4.9.2-1~deb9u1) ...
Errors were encountered while processing:
W: --force-yes is deprecated, use one of the options starting with --allow instead.
E, [2020-09-14T18:18:40.608072 #2218] ERROR -- gdu-server: E: Sub-process /usr/bin/dpkg returned an error code (1) (Bycast::Tasks::GduServer::ApplyHotfix::Error)
E, [2020-09-14T18:18:40.608140 #2218] ERROR -- gdu-server:    /usr/local/lib/site_ruby/bycast/tasks/gdu-server/apply-hotfix.rb:229:in `install'
E, [2020-09-14T18:18:40.608160 #2218] ERROR -- gdu-server:    /usr/local/lib/site_ruby/bycast/tasks/gdu-server/apply-hotfix.rb:81:in `apply_to_node'
E, [2020-09-14T18:18:40.608174 #2218] ERROR -- gdu-server:    /usr/local/lib/site_ruby/bycast/tasks/gdu-server/apply-hotfix.rb:69:in `block in apply_to_other_nodes'
E, [2020-09-14T18:18:40.608196 #2218] ERROR -- gdu-server: Failed to apply hotfix to gatewaynode1: E: Sub-process /usr/bin/dpkg returned an error code (1)
New to NetApp?
Scan to view the article on your device
