跳转到主内容
计算控制器的温度超过标称阈值 StorageGRID 设备
139
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
适用于
  • StorageGRID Appliance
  • SG1000
  • SG1100
问题
  • 其中一个设备在 StorageGRID 仪表板上显示警报;其他设备工作正常:
    • The temperature of the compute controller in a StorageGRID appliance has exceeded a nominal threshold
    • Appliance compute controller chassis temperature too high
    • DAS drive failed
    •  Appliance FAN fault detected
Temperature of compute controller exceed nominal threshold StorageGRID Appliance
  • 节点无响应,但 BMC 接口仍可访问。
  • BMC 日志显示关键 CPU 温度警报(例如,101°C),橙色 LED 指示灯闪烁。
Event ID  Time Stamp    Severity Sensor Name   Sensor Type   Description
 284  Jan/9/2026   03:52:51  [Information] [Login Info] [Login success] Login success -- Account: admin/  IP:10.121.10.160
 283  Jan/8/2026   04:30:09  [Critical]  [Temp_CPU1] [Temperature] Upper Critical - Going High (Reading: 101 deg C/ Threshold: 101 deg C) - Asserted
 282  Jan/8/2026   04:30:09  [Warning]  [Temp_CPU1] [Temperature] Upper Non-Critical - Going High (Reading: 101 deg C/ Threshold: 101 deg C) - Asserted
 281  Jan/8/2026   04:30:09  [Critical]  [Temp_CPU0] [Temperature] Upper Critical - Going High (Reading: 101 deg C/ Threshold: 101 deg C) - Asserted
 280  Jan/8/2026   04:30:09  [Warning]  [Temp_CPU0] [Temperature] Upper Non-Critical - Going High (Reading: 101 deg C/ Threshold: 101 deg C) - Asserted
New to NetApp?
