存储节点关闭超过15天、无法重建cassand拉
适用场景
- NetApp StorageGRID
问题描述
- 存储节点脱机超过15天
- cassand拉 服务处于"错误"状态
- check-cassandrebuild脚本失败、并显示以下错误:
Warning: Unable to determine what address to replace. Using eth0 10.X.XX.XX instead.
warning: Command "etc/init.d/cassandra start" failed with result "starting cassandra … failed to start: entering error state." exit code 1". Failed to start cassandra service
- StorageGRID /var/local/log/servermanager.log显示:
cassandra not started because it has been offline for longer than its 15 day grace period - rebuild cassandra
- StorageGRID /var/local/log/system.log显示:
Exception encountered during startup
