跳转到主内容
StorageGRID audit.log 未轮换, /var/local/audit/export/ 已满
9
Visibility:
Internal
Votes:
0
Category:
storagegrid<a>2009036932</a>
Specialty:
sgrid
Last Updated:
适用场景
StorageGRID 11.4.
问题描述
  • audit.log 未轮换
  • Use% 的 /var/local/audit/export/ 为 100%
Command: df -h
Result:
Filesystem    Size  Used Avail Use% Mounted on
/dev/sdc     200G  200G   28K 100% /var/local/audit/export
  • manage-audit.log 显示 Unhandled error
 INFO -- clean: starting, with mode "clean" and PID <PID>
 INFO -- clean: attempting to lock audit management
 INFO -- clean: beginning audit log management session (mode clean, pid <PID>)
ERROR -- clean: Unhandled error. Unable to manage audit logs.
ERROR -- clean: Active log /var/local/audit/export/audit.log must be a file (Bycast::Logs::Directory::FileArgumentError)
ERROR -- clean:    /usr/local/sbin/manage_audit_logs.rb:159:in `initialize'
ERROR -- clean:    /usr/local/sbin/manage_audit_logs.rb:632:in `new'
ERROR -- clean:    /usr/local/sbin/manage_audit_logs.rb:632:in `initialize'
ERROR -- clean: Exiting...
New to NetApp?
This is an internal KB article and its content should not be copy/pasted and shared with people outside of NetApp. Always seek Duty Manager authentication of caller for password reset requests. If you need further assistance post a question in Knowledge Xchange
