跳转到主内容
启用验证证书时,StorageGRID 每周 AutoSupport 失败
10
Visibility:
Votes:
0
Category:
storagegrid-webscale
Specialty:
sgrid
Last Updated:
适用于
  • NetApp StorageGRID
  • 启用了验证证书的 AutoSupport
问题
  • 启用"验证证书"选项后,StorageGRID 无法使用 HTTPS 发送 AutoSupport。
  • Grid Manager 报告:AutoSupport message failed to send 和结果选项卡记录 每周 AutoSupport 失败
  • /var/local/log/nms.log 记录:
    • ERROR SSL_connect returned=1 errno=0 state=error: certificate verify failed (unable to get local issuer certificate) (Faraday::SSLError)
  • /var/local/log/bycast-err.log 记录:
    • ERROR Connection to autosupport destination https://support.netapp.com:443 failed with error SSL_connect returned=1 errno=0 state=error: certificate verify failed (unable to get local issuer certificate)
  • 禁用证书验证(不验证证书) 允许成功发送 ASUP 消息。
  • wget连接到 ASUP 服务器,但无法解析证书:
root@admin_node:~ # wget https://support.netapp.com/put/AsupPut/
--2026-07-16 17:23:29-- https://support.netapp.com/put/AsupPut/
Resolving support.netapp.com (support.netapp.com)... 216.240.21.18
Connecting to support.netapp.com (support.netapp.com)|216.240.21.18|:443... connected.
ERROR: The certificate of ‘support.netapp.com’ is not trusted.
ERROR: The certificate of ‘support.netapp.com’ doesn't have a known issuer.
  • telnet 到 ASUP 服务器时显示 Connected:
root@admin_node:~ # telnet 216.240.21.18 443
Trying 216.240.21.18...
Connected to 216.240.21.18.
Escape character is '^]'.
Connection closed by foreign host.
  • 运行 traceroute support.netapp.com 显示在特定 IP 地址处停止。
New to NetApp?
