跳转到主内容
StorageGRID 设备报告存储设备存储连接已降级并检测到光纤通道链接错误
106
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
适用于
  • NetApp StorageGRID 设备
  • NetApp E 系列
问题描述
StorageGRID GRID Manager 报告:
Storage appliance storage connectivity degraded
There is a problem with one or more connections between the compute controller and storage controller.
  • Major Event Log  在 E-Series 控制器上可能报告以下事件:
Fibre channel link errors continue (Event type 1206)
Fibre channel link errors - threshold exceeded (Event type 1207)
示例:
Event type: 1206 / 1207
Event category: Error
Priority: Informational
Event needs attention: false
Description: Fibre channel link errors continue Fibre channel link errors - threshold exceeded
Component location: Host-side: controller in bay B, port 4
Logged by: Controller in bay B
  • STORAGE-ARRAY-PROFILE 在 E-Series 控制器上可能会报告光纤通道端口已Down
    Host interface:          Fibre
     Host Interface Card(HIC):    Baseboard
     Channel:            2
     Port:              0b
     Current ID:           126/0x0
     Preferred ID:          1/0xE8
     NL-Port ID:           0x000000
     Maximum data rate:       16 Gbps
     Current data rate:       4 Gbps
     Data rate control:       Auto
     Link status:          Down
  • fcDumpSTATE-CAPTURE-DATA 上的 E-Series 控制器可能会报告 错误 和/或 错误字符的增加:
2806-B Our Num ::...Exchange Counts...:: Num ..Link Up.. Chip LinkStat Port Port :: :: Link Bad Bad ID Logi ::Open Total Errors:: Down Char Frame 2-Src Up-Ptp 2 2 :: 2 106083407 0:: 0 0 0 3-Src Up-Ptp 2 2 :: 0 0 2969:: 0 -415122385 0
New to NetApp?
