跳转到主内容
间歇性无法与单个节点上的节点通信警报
72
Visibility:
Votes:
0
Category:
storagegrid-webscale<a>2009714389.</a>
Specialty:
sgrid
Last Updated:
适用场景
NetApp StorageGRID
问题描述
  • 'Unable to communicate with node' 单个节点上出现间歇性警报、可在几分钟内自行解析。
  • Dynip.log 从有问题的节点指示:
[2023-08-22T14:24:52.795]DummyThread-1125493 -   ERROR --Exception in send_node_update Traceback(most recent call last):
  File"/usr/lib/python2.7/dist-packages/dynip/threads/heartbeat.py", line155, in send_node_update
    response = send_request(msg_id, ipaddr,path, 'PUT', body)
  File"/usr/lib/python2.7/dist-packages/dynip/threads/heartbeat.py", line116, in send_request
    response = urlopen(request, timeout=10,context=_ssl_context)
  File"/usr/lib/python2.7/urllib2.py", line 154, in urlopen
    return opener.open(url, data, timeout)
  File"/usr/lib/python2.7/urllib2.py", line 429, in open
    response = self._open(req, data)
  File"/usr/lib/python2.7/urllib2.py", line 447, in _open
    '_open', req)
  File"/usr/lib/python2.7/urllib2.py", line 407, in _call_chain
    result = func(*args)
  File"/usr/lib/python2.7/urllib2.py", line 1241, in https_open
    context=self._context)
  File"/usr/lib/python2.7/urllib2.py", line 1201, in do_open
    r = h.getresponse(buffering=True)
  File"/usr/lib/python2.7/httplib.py", line 1137, in getresponse
    response.begin()
  File"/usr/lib/python2.7/httplib.py", line 448, in begin
    version, status, reason =self._read_status()
  File"/usr/lib/python2.7/httplib.py", line 412, in _read_status
    raise BadStatusLine("No status linereceived - the server has closed the connection")
BadStatusLine:No status line received - the server has closed the connection
  • Dynip.log 来自其他存储节点表示:
[2023-08-22T14:15:12.091]DummyThread-1123635 - WARNING -- Update to (NODE_NAME) (IP_ADDRESS) failed:('The read operation timed out',)
[2023-08-22T14:18:36.155]DummyThread-1123873 - INFO -- Received heartbeat from node (NODE_NAME) (IP_ADDRESS)
New to NetApp?
