跳转到主内容
在 StorageGRID 服务设备上检测到设备 DAS 驱动器故障
158
Visibility:
Votes:
0
Category:
storagegrid-webscale
Specialty:
sgrid
Last Updated:
适用于
  • NetApp StorageGRID
  • SG100/SG1000/SG110/SG1100/SG6112 服务设备
问题
  • StorageGRID UI 报告警报:Appliance DAS drive fault detected. A problem was detected with a direct-attached storage (DAS) drive in the appliance
  • 在 Grid Manager > 帮助 (?)> API Documentation > alerts > GET > Try it out 列出了受影响的插槽:
"alertname": "Appliance DAS drive fault detected",
"firmware_version": "XXXX",
"instance": "admin_node_name",
"job": "miscd",
"model_name": "XXXXX",
"name": "nvme1n1",
"node_id": "1XXXXX",
"serial_number": "XXXXX",
"severity": "critical",
"site_id": "XXXX",
"site_name": "site_name",
"slot": "HDD03",
"x_part_number": "H610S-SSD-960GB-B"
  • 新的支持案例可能会由 AutoSupport 使用以下标题自动打开。
StorageGRID Notification from xxxxx (HARDWARE FAILURE - Component: SSD, Slot: HDD03, PartNumber: X4131A)
New to NetApp?
