跳转到主内容
SnapCenter 无法间歇性地触发选择控制阀备份作业,原因是“尝试锁定时发现死锁”错误
18
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用于
  • SnapCenter 服务器
  • 适用于 VMware vSphere (选择控制阀)的 SnapCenter 插件
问题
  • 如果将多个选择控制阀备用作业配置为同时运行, SnapCenter 将无法间歇地触发备用作业。
  • 未创建备份作业 ID 。
  • 不会发送有关备份运行失败的电子邮件通知。
  • SnapManagerWeb.log 报告以下错误。
ERROR SnapManagerWeb PID=[XXXX] TID=[XXX] Exception in method: CanExecute.
Deadlock found when trying to get lock; try restarting transaction : Detailed Exception Deadlock found when trying to get lock; try restarting transaction : BaseException Deadlock found when trying to get lock; try restarting transaction
ERROR SnapManagerWeb PID=[XXXX] TID=[XXX] ErrorCode (-1), ErrorMessage (Deadlock found when trying to get lock; try restarting transaction)
ERROR SnapManagerWeb PID=[XXXX] TID=[XXX] ErrorCode (110), ErrorMessage (Failed to add an entry to NLB job monitor for '<POLICY_NAME>' from node '<HOSTNAME>'.)
New to NetApp?
