跳转到主内容
用于 SAP Hana 备份的安全数据库连接
13
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
适用于
适用于 SAP HANA 的 SnapCenter 插件( SCHANA )
问题
向 SAP HANA 添加额外的 SSL 参数时,备份将失败,并显示以下hdbsql错误:
This command fails with error: [/hana/shared/HEA/hdbclient/hdbsql -U HEABACKUP -e -sslprovider commoncrypto -sslkeystore /usr/sap/HEA/HDB20/hdb20hea-001/sec/sapsrv.pse -ssltruststore /usr/sap/HEA/HDB20/hdb20hea-001/sec/sapsrv.pse -sslhostnameincert hvm034: Command not found.].
 Set valid HDBSQL_CMD for the SAP HANA plug-in on this host using "Set-SmConfigSettings -Plugin -HostName hostname -PluginCode hana ?configSettings @{"HANA_HDBSQL_CMD"="path_to_HDBSQL_CMD"} " PowerShell cmdlet from SnapCenter Server.
[2020-03-20 13:12:56,017] ERROR:
[10.1.54.120:9090(4.3.0.0)] SCF-00037: Application quiesce for plug-in [hana] failed with error [] and exit code [1], Exiting!
New to NetApp?
