跳转到主内容
尝试从 SnapCenter vSphere 插件 4.0 还原虚拟机中的文件时,无法使用指定凭据访问来宾系统
196
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用于
  • 适用于 VMware 的 SnapCenter 插件( SCV ) 4.0-4.1.1
  • NetApp 数据代理( NDB )
  • 适用于 VMware 的 SnapCenter 插件( SCV ) 4.3 及更高版本
问题描述
尝试运行子系统文件还原的错误消息:
Failed to access guest system using specified credentials.
Please verify VMWare tools is installed/running on the system and account used has domain administrator privileges.
Error is ApiException Failed to start process in guest system SystemError vix error codes = (3004, 0).
见 vmcontrol_jetty_server.log:
com.netapp.nvpf.api.model.ApiException: Failed to access guest system using specified credentials.
Verify if VMWare tools is installed or running on the system and the account is built-in administrator account. Error is ApiException  Failed to start process in guest system InvalidGuestLogin
New to NetApp?
