跳转到主内容
使用Installer 4.8升级SLES 11 SP3或SP4上的SC Linux插件失败
51
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
  • 适用于Linux的SnapCenter Plug-in for Oracle (SCO) 4.8及更高版本
  • 适用于Linux的SnapCenter Plug-in for SAP HANA (SCHANA)、版本4.8及更高版本
  • 适用于Linux的SnapCenter Creator插件(SCC) 4.8及更高版本
  • SUSE Linux Enterprise System (SLES)版本11、Service Pack 3或4
  • RHEL Linux最高7.5
问题描述
尝试在带有Service Pack 3或4的SLES 11上运行安装程序时、安装程序会失败并显示以下错误:
Installation of the package "snapcenter_linux_host_plugin.bin" failed on the host "joda.sip.local" with ErrorCode:1, error:
[root][Fri Feb 17 15:01:55 CET 2023] - readlink is available. Using default readlink implementation.
. Installation logs have been placed under the directory "/var/opt/snapcenter/logs/" on the host.
从Linux主机检索到的安装日志本身显示:
installRpm: Executable Command: rpm -Uvh
--nodeps --relocate /opt=/opt  netapp-snapcenter-plugin-loader-4.8.x86_64.rpm netapp-snapcenter-plugin-unix-4.8.x86_64.rpm
netapp-snapcenter-plugin-oracle-4.8.x86_64.rpm  --ignoreos --nodigest --nofiledigest
--nofiledigest: unknown option
New to NetApp?
