跳转到主内容
重新启动ESXi后、选择控制阀虚拟设备启动停止
398
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>2009年674086</a>
Last Updated:
适用场景
适用于 VMware vSphere (选择控制阀)的 SnapCenter 插件
问题描述
  • 重新启动ESXi后、选择控制阀虚拟设备启动停止、并显示消息:
Booting SnapCenter Plug-in for VMware vSphere virtual appliance... Please wait...
  • 按 Alt+F2后、控制台将显示消息:
[  OK  ] Reached target Local File Systems.
     Starting Create Volatile Files and Directories...
     Starting Preprocess NFS configuration...
     Starting netfiIter persistent configuration.
[  OK  ] Started Preprocess NFS configuration.
[  OK  ] Reached target NFS client services.
[  OK  ] Started Create Volatile Files and Directories.
     Starting RPC bind portmap service...
     Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about Systen Boot/Shutdown.
     Starting Update UTMP about System Runlevel Changes...
[  OK  ] Started Update UTMP about System Runlevel Changes.
[  OK  ] Started RPC bind portnap service.
[  OK  ] Reached target Remote File Systems (Pre).
[  OK  ] Reached target Remote Fi le Systems.
[  OK  ] Reached target RPC Port Mapper.
[  OK  ] Started netfiIter persistent configuration.
[  OK  ] Reached target Network (Pre).
     Starting Raise network interfaces...
[  OK  ] Started Raise network interfaces.
[  OK  ] Reached target Network.
[  OK  ] Reached target Network is Online.
You are in emergency mode. After logging in, type "journalctl -xb" to view
system logs, "systemctl reboot" to reboot, "systemctl default" or "exit"
to boot into default mode.
Cannot open access to console, the root account is locked.
See sulogin(8) man page for more details.
Press Enter to continue.
New to NetApp?
