跳转到主内容
使用ONTAPI的软件在https SVM连接上超时21秒
29
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>2009216915</a>
Last Updated:
适用场景
  • SnapCenter服务器、适用于Windows的SnapCenter插件(SCW)
  • 适用于Windows和Unix的SnapDrive (SDW、SDU)
  • Snap Creator Framework (SCF)
问题描述
尝试在ONTAP SVM上运行操作时、该软件在https上收到超时消息、恰好超过21秒。
SMCore/SALSnpDrvDbg 调试日志中来自SnapCenter的错误消息示例:
The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop:
Connection to <SVM_MGMT_IP_ADDR> on port 443 for protocol HTTPS timed out.
at System.Management.Automation.Runspaces.PipelineBase.Invoke(IEnumerable input)
at SnapDrive.Nsf.Core.Storage.StorageConnection.InitializeONTAP(SDStorageSystemId storageSystemId)
在Snap Creator Framework中、调试日志会显示21秒的间隙、例如:
[<DATE> 06:00:00,167] INFO: Validating policy: daily finished successfully
########## Detecting Data ONTAP mode for 10.193.8.185 ##########
[<DATE> 06:00:21,205] INFO: STORAGE-03031: Getting system version details of [<IP_ADDR>]
[<DATE> 06:00:21,205] ERROR: com.netapp.snapcreator.storage.executor.ZapiExecutorException: java.net.ConnectException: Connection timed out: connect
New to NetApp?
  • 这篇文章对您有帮助吗?
