SnapCenter升级无法在暂存期间提取文件
适用场景
SnapCenter服务器(SC)
问题描述
在SCExtr拖拉机.msi上的"暂存"步骤中升级SnapCenter服务器失败。
指示以下错误消息 :
并在日志中指示以下内容:
9-30-2024[11:01:42 AM]: Engine: property 'ISParcelStatus' value now 'SCExtractor.msi'9-30-2024[11:01:42 AM]: Failed to extract '{77FCFD36-CA9E-41D2-BCB3-9193060077DD}\SCExtractor.msi' from setup stream, error 09-30-2024[11:01:42 AM]: Engine: exception status 80040709 while staging parcels9-30-2024[11:01:42 AM]: UI DLL: Display Error: Failed to extract a file while staging. Either the file is not present in the stream, or the file could not be written to the target machine. File: {77FCFD36-CA9E-41D2-BCB3-9193060077DD}\SCExtractor.msi9-30-2024[11:01:50 AM]: Error code: 0x80040709
