跳转到主内容
升级到SC 5.0后、SnapCenter保留失败
135
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
  • SnapCenter服务器(SC) 5.0
  • 适用于SQL的SnapCenter插件(SCSQL)
  • 适用于Exchange的SnapCenter插件(SCE)
  • ONTAP 9.14.1P2及更高版本
  • PowerShell工具包(PSTK)
问题描述
在升级到SnapCenter Server并将SCSQL"插件升级到5.0之后、SQL 备份保留开始失败、并显示以下错误:
SnapCenter UI:
Full Backup retention failed with error: Retention: Error: Snapshot enumeration failed. The operation has timed out
SMCoreService.log:
DEBUG SMCore PID=[5776] TID=[43] Command: Remove-NcSnapshot. Storage System: <SVM_IP>. Version: NetApp Release 9.14.1P2: Tue Mar 19 23:28:08 UTC 2024. Connection Mode: REST
DEBUG SMCore PID=[5776] TID=[43] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: Record doesn't exist
DEBUG SMCore PID=[5776] TID=[43] Remove Snapshot <RGROUP_NAME>_<HOST_FQDN>_<DATE>_<TIME>.#### on <SVM_NAME> is failed. Error: 102
DEBUG SMCore PID=[5776] TID=[43] Command: Get-NcSnapshot. Storage System: <SVM_IP>. Version: NetApp Release 9.14.1P2: Tue Mar 19 23:28:08 UTC 2024. Connection Mode: REST
DEBUG SMCore PID=[5776] TID=[43] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: The operation has timed out
SnapManagerWeb_<Job_ID>.log:
ERROR SnapManagerWeb_34643 PID=[4188] TID=[257] ErrorCode (-1), ErrorMessage (Error: Snapshot enumeration failed.
WARN  SnapManagerWeb_34643 PID=[4188] TID=[257] DeleteSnapshotInfo failed with errorcode: -1. Erro message: Error: Snapshot enumeration failed.
ERROR SnapManagerWeb_34643 PID=[4188] TID=[257] RemoveBackupComponentByBackupAndResourceId failed: Error: Snapshot enumeration failed.
ERROR SnapManagerWeb_34643 PID=[4188] TID=[257] Asynchronous retention failed for backupId: <BU_ID>, backupJobId: <JOB_ID> with error: Retention : Error: Snapshot enumeration failed.
New to NetApp?
