跳转到主内容
SnapCenter无法删除已从存储中删除的克隆
373
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
  • SnapCenter服务器(SC) 4.1.1及更高版本
  • 适用于Oracle的SnapCenter插件(SCO) 4.1.1及更高版本
  • 适用于Microsoft SQL Server的SnapCenter插件(SCSQL) 4.1.1及更高版本
问题描述
  • 无法通过GUI或PowerShell (PS)命令从SC中删除克隆"Remove-SmClone -CloneName <Clone_Name> -Force"
  • 在 SnapCenter图形用户界面中出现以下错误:
Cannot delete clone as there are clones present for database . Delete clone(s) , <Clone_Name>
  •   删除克隆作业的SMCore日志中显示以下错误:
"ERROR SMCore_<job_ID> PID=[4172] TID=[37] Exception in method: InvokeXML. System.InvalidOperationException: There is an error in XML document (1, 57). ---> System.InvalidOperationException: <SmResponse xmlns=''> was not expected. at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderSmCanExecuteResponse.Read21_SmCanExecuteResponse() --- End of inner exception stack trace --- at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events) at System.Xml.Serialization.XmlSerializer.Deserialize(Stream stream) at SnapMgrHelper.RestAdapter.InvokeXML[TReq,TRes](TReq request, String methodType, String remoteURL, Boolean xmlSerializer, Boolean removeXMLNamespace, Boolean dataContractDeserializer, Boolean logRequest, Boolean logResponse) : Detailed Exception There is an error in XML document (1, 57). <SmResponse xmlns=''> was not expected. : BaseException System.InvalidOperationException: <SmResponse xmlns=''> was not expected. at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderSmCanExecuteR"
  •      删除克隆作业的<JobID>日志中会显示以下错误:
ERROR SnapManagerWeb_<JobID> PID=[xxxx] TID=[xxx] Can not delete clone as there are clones present for database. Delete clone(s) , <Clone_Name>
DEBUG SnapManagerWeb_<JobID> PID=[xxxx] TID=[xxx] System.Exception: Cannot delete clone as there are clones present for database . Delete clone(s) , <Clone_Name>
ERROR SnapManagerWeb_<JobID> PID=[xxxx] TID=[xxx] ErrorCode (-1), ErrorMessage (Cannot delete clone as there are clones present for database . Delete clone(s) , <Clone_Name>)
New to NetApp?
