SnapCenter无法升级到4.9或5.0版
- 8
- Visibility:
- Public
- Votes:
- 0
- Category:
- snapcenter
- Specialty:
- snapx<a>SC服务器</a><a>2010049978</a>
- Last Updated:
适用场景
- SnapCenter服务器4.9
- SnapCenter服务器5.0
问题描述
- 尝试将SnapCenter服务器升级到版本4.9或5.0时、将失败、并显示以下内容
- 从
MySQLInstaller日志中:
Starting the server
Attempting to start service MySQL57...
[System] [MY-010116] [Server] C:\Program Files\MySQL\MySQL Server 8.0\bin\mysqld.exe (mysqld 8.0.35) starting as process 6684
[Warning] [MY-013869] [InnoDB] Ignored deprecated configuration parameter innodb_log_file_size. Used innodb_redo_log_capacity instead.
[ERROR] [MY-000058] [Server] Unknown suffix '.' used for variable 'mysqlx-port' (value '0.0').
[Warning] [MY-000081] [Server] option 'mysqlx-port': unsigned value 0 adjusted to 1.
[ERROR] [MY-000077] [Server] C:\Program Files\MySQL\MySQL Server 8.0\bin\mysqld.exe: Error while setting value '0.0' to 'mysqlx-port'.
ERROR] [MY-010746] [Server] Parsing options for plugin 'mysqlx' failed.
[System] [MY-011012] [Server] Starting upgrade of data directory.
[System] [MY-013576] [InnoDB] InnoDB initialization has started.
[System] [MY-013577] [InnoDB] InnoDB initialization has ended.
2 [System] [MY-011003] [Server] Finished populating Data Dictionary tables with data.
[System] [MY-013381] [Server] Server upgrade from '50700' to '80035' started.
[System] [MY-013381] [Server] Server upgrade from '50700' to '80035' completed.
[Warning] [MY-010068] [Server] CA certificate ca.pem is self signed.
[System] [MY-013602] [Server] Channel mysql_main configured to support TLS. Encrypted connections are now supported for this channel.
[ERROR] [MY-000067] [Server] unknown variable 'mysqlx_port=0.0'.
[ERROR] [MY-010119] [Server] Aborting
[System] [MY-010910] [Server] C:\Program Files\MySQL\MySQL Server 8.0\bin\mysqld.exe: Shutdown complete (mysqld 8.0.35) MySQL Community Server - GPL.- Error!
Configuration of MySQL Server 8.0.35 has completed unsuccessfully! (Check the log for more details)
Finished configuring all selected products.
Install MySQL Server.Log: Installation completed
InstallMySQL.Log: Skip the MySQL Password Configuration, Because we performed the MySQL upgrade operation
Main Log: MySQL Community Installation completed successfully.- 在GUI中:
SnapCenter repository is not accessible. Error: The Entity Framework provider type 'Devart.Data.MySql.Entity.MySqlEntityProviderServices, Devart.Data.MySql.Entity.EF6 , Version=8.5.658.0, Culture=neutral, PublicKeyToken=09af7300eec23701' registered in the application config file for the ADO.NET provider with invariant name 'Devart.Data.MySql' could not be loaded. Make sure that the assembly-qualified name is used and that the assembly is available to the running application. See http://go.microsoft.com/fwlink/?LinkId=260882 for more information.
