SnapCenter 无法间歇性地触发选择控制阀备份作业,原因是“尝试锁定时发现死锁”错误
适用于
- SnapCenter 服务器
- 适用于 VMware vSphere (选择控制阀)的 SnapCenter 插件
问题
- 如果将多个选择控制阀备用作业配置为同时运行, SnapCenter 将无法间歇地触发备用作业。
- 未创建备份作业 ID 。
- 不会发送有关备份运行失败的电子邮件通知。
SnapManagerWeb.log
报告以下错误。
ERROR SnapManagerWeb PID=[XXXX] TID=[XXX] Exception in method: CanExecute.
Deadlock found when trying to get lock; try restarting transaction : Detailed Exception Deadlock found when trying to get lock; try restarting transaction : BaseException Deadlock found when trying to get lock; try restarting transaction
ERROR SnapManagerWeb PID=[XXXX] TID=[XXX] ErrorCode (-1), ErrorMessage (Deadlock found when trying to get lock; try restarting transaction)
ERROR SnapManagerWeb PID=[XXXX] TID=[XXX] ErrorCode (110), ErrorMessage (Failed to add an entry to NLB job monitor for '<POLICY_NAME>' from node '<HOSTNAME>'.)
