SnapCenter无法使用ONTAP 9.14.x为快照附加标签
适用场景
- SnapCenter服务器(SC) 5.0
- 适用于Microsoft Exchange Server (SCE) 5.0的SnapCenter插件
- 适用于Microsoft SQL Server (SCSQL) 5.0的SnapCenter插件
- 适用于Microsoft Windows 5.0的SnapCenter插件
- ONTAP 9.14.1或更高版本
问题描述
添加新的ONTAP 9.14.1集群后,SnapCenter无法为备份期间创建的快照附加标签。
在SMCore_SMC.log中可以看到以下错误<JobID>:
ERROR SMCore_<JobID> PID=[xxxx] TID=[xx] ReplicationActivity - Set label for Storage : <SVM_Name>, Volume : <Volume_Name>, Snapshot : <Snapshot_Name>, Label : <Label_Name> failed with error SetSnapshotLabel failed : 102, Failed to attach the label to the specified Snapshot copy.(<Snapshot_Name>)Invalid response returned by Set-NcSnapshot: 0ERROR SMCore_<JobID> PID=[xxxx] TID=[xx] ErrorCode (-1), ErrorMessage (SetSnapshotLabel failed : 102, Failed to attach the label to the specified Snapshot copy.(<Snapshot_Name>)Invalid response returned by Set-NcSnapshot: 0[500]: The snapshot name does not exist. Unable to find Snapshot version UUID with error: Error: Snapshot enumeration failed. [500]: The snapshot name does not exist. Unable to find SnapMirror destination(s). Error: No SnapMirror relationships were found. Resolution: Please make sure that secondary storage systems are registered and host can resolve them correctly.Unable to find SnapVault destination for the source volume(s) <Source_SVM> : <Source_Volume1>, <Source_SVM> : <Source_Volume2>. SetSnapshotLabel failed : 102, Failed to attach the label to the specified Snapshot copy.(<Snapshot_Name>)Invalid response returned by Set-NcSnapshot: 0. SetSnapshotLabel failed : 102, Failed to attach the label to the specified Snapshot copy.(<Snapshot_Name>)Invalid response returned by Set-NcSnapshot: 0
