跳转到主内容
SnapCenter克隆或验证失败、并显示聚合不存在
127
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
适用场景
  • 适用于VMware vSphere的SnapCenter插件 (SCV)
  • SnapCenter 应用程序插件
    • 适用于Windows的SnapCenter插件(SCW)
    • 适用于SQL的SnapCenter插件(SCSQL)
    • 适用于Oracle的SnapCenter插件(SCO)
    • 适用于SAP HANA的SnapCenter插件(SCSAP)
    • 适用于Customer Creator (SCC)的SnapCenter插件:DB2、Sybase、PostgreSQL、MySQL等
问题描述
SnapCenter克隆或验证作业将失败、并显示以下错误消息:
日志位置 错误
适用于VMware的SnapCenter插件
  • Unable to mount datastores: <DATASTORE> in Backup: <XXXX>. Failed to create LUN clone null on volume null null
  • [JobId:XXXX] Failed to create LUN clone <Clone Name> on volume <Volume IP>:/vol/<Vol path> Failed to create the volume clone.
  • Cannot create volume. Reason: aggregate <Aggregate-Name> is not in aggr-list of Vserver <Vserver-Name>.
  • Exception while calling pre-restore on SCV: Unable to mount datastores: in Backup: <backup>.Failed to create LUN clone null on volume null null
SnapCenter SMCore Error SAL PID=[XXXX] TID=[XXXX] Failed to create the volume clone. Aggregate <aggregate name> does not exist
SnapCenter 应用程序插件 作业日志
Error SDW PID=[3744] TID=[14412] Flexclone of volume: <volume> failed.
Cannot create volume. Reason: aggregate <aggregate> is not in aggr-list of Vserver <SVM>.
Failed to clone resources, error isMount operation failed with error Failed to mount storage resource, error is
Aggregate <aggregate name> not found. Reason: entry doesn't exist.
Windows应用程序事件日志
Activity 'Cloning Resources' failed with error: Failed to clone resources, error is Mount operation failed with error Failed to mount storage resource, error is
Activity 'Cloning Resources' failed with error: Failed to clone resources, error isMount operation failed with error Failed to mount storage resource, error is Failed to create the volume clone.
New to NetApp?
