跳转到主内容
SnapCenter 备份、验证或克隆作业失败,出现错误"未找到指定的 Vserver"
68
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用于
  • SnapCenter Server (SC) 6.0、6.0.1、6.1
  • SnapCenter Plug-in for Microsoft SQL Server (SCSQL) 6.0、6.0.1、6.1
  • SnapCenter Plug-in for Microsoft Exchange Server (SCE) 6.0、6.0.1、6.1
  • ONTAP 9.14.1 及更高版本
  • NetApp ONTAPI (ZAPI)
  • 备份、克隆或验证作业
问题
  • SC 备份或克隆/验证作业失败,出现错误:
<installation_path>\Program Files\NetApp\SnapCenter\SMCore\log\SMCore_<id>.log
DEBUG SMCore_102 PID=[7940] TID=[27] REST Mode: Invoke-NcCli. cmd = volume clone create
DEBUG SMCore_102 PID=[7940] TID=[27] Invoking Invoke-NcCli command
DEBUG SMCore_102 PID=[7940] TID=[27] Command: Invoke-NcCli. Storage System: <SVM>. Version: NetApp Release 9.14.1P5: Sat May 18 19:42:16 UTC 2024. Connection Mode: REST
DEBUG SMCore_102 PID=[7940] TID=[27] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: [400]: Specified Vserver not found
  • 在 SC 6.0 上,它可能失败,指示 Specified Vserver not found ,以防 ZAPI 被禁用或 ONTAP 版本在 9.13.1 和 9.15 之间:
DEBUG SMCore_433327 PID=[1320] TID=[183] ZAPI Mode: Invoke-NcCli. cmd = volume clone create
DEBUG SMCore_433327 PID=[1320] TID=[183] Invoking Invoke-NcCli command
DEBUG SMCore_433327 PID=[1320] TID=[183] Command: Invoke-NcCli. Storage System: <SVM> Version: NetApp Release 9.14.1P7: Thu Aug 01 03:07:44 UTC 2024. Connection Mode: ZAPI. Username: <user>. Storage added as VSERVER_DIRECT.
2024-09-02T02:31:48.6446746+02:00 DEBUG SMCore_433327 PID=[1320] TID=[183] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: [400]: Specified Vserver not found
  • 在 ONTAP ASUP 中的 AUDIT-MLOG-TXT.GZ 日志中看到错误:
Error: Specified Vserver not found
New to NetApp?
