跳转到主内容
SnapCenter备份或克隆失败、并显示错误:未找到指定的Vserver
6
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
  • SnapCenter服务器(SC) 5.0| 5.0P1 | 6.0
  • 适用于Microsoft SQL Server的SnapCenter插件(SCSQL) 5.0| 5.0P1 | 6.0
  • 适用于Microsoft Exchange Server的SnapCenter插件(SCE) 5.0| 5.0P1 | 6.0
  • ONTAP 9.14.1及更高版本
  • NetApp ONTAPI (ZAPI)
问题描述
  • SC备份或克隆/验证作业 失败 、并显示错误:
<installation_path>\Program Files\NetApp\SnapCenter\SMCore\log\SMCore_<id>.log:
DEBUG SMCore_102 PID=[7940] TID=[27] REST Mode: Invoke-NcCli. cmd = volume clone create
DEBUG SMCore_102 PID=[7940] TID=[27] Invoking Invoke-NcCli command
DEBUG SMCore_102 PID=[7940] TID=[27] Command: Invoke-NcCli. Storage System: <SVM>. Version: NetApp Release 9.14.1P5: Sat May 18 19:42:16 UTC 2024. Connection Mode: REST
DEBUG SMCore_102 PID=[7940] TID=[27] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: [400]: Specified Vserver not found
  • 在SC 5.0P1和6.0上, 如果 ZAPI已 禁用 或 ONTAP版本为9.13.1和9.15,则可能无法指示Specified Vserver not found
DEBUG SMCore_433327 PID=[1320] TID=[183] ZAPI Mode: Invoke-NcCli. cmd = volume clone create
DEBUG SMCore_433327 PID=[1320] TID=[183] Invoking Invoke-NcCli command
DEBUG SMCore_433327 PID=[1320] TID=[183] Command: Invoke-NcCli. Storage System: <SVM> Version: NetApp Release 9.14.1P7: Thu Aug 01 03:07:44 UTC 2024. Connection Mode: ZAPI. Username: <user>. Storage added as VSERVER_DIRECT.
2024-09-02T02:31:48.6446746+02:00 DEBUG SMCore_433327 PID=[1320] TID=[183] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: [400]: Specified Vserver not found
  • 在ONTAP AutoSupport的AUDIT-MLOG-TXT.GZ 日志中出现错误:
Error: Specified Vserver not found
New to NetApp?
