SnapCenter 插件安装失败:未找到网络路径
适用于
- SnapCenter 服务器(SC)
- SnapCenter Plug-in for Microsoft SQL Server (SCSQL)
问题
- 无法添加主机来安装 SCSQL:
- 已安装 Microsoft .Net Framework v4.5.2 或更高版本以及 Windows PowerShell v4.0 或更高版本。
- 将 SnapCenter 插件推送到主机时,它将失败,并显示以下错误消息:
2021-06-22T22:47:53.5269175+08:00 ERROR SnapManagerWeb_71 PID=[6048] TID=[97] Unable to get the .NET Framework Information from registry. Error : The network path was not found.
Source: mscorlib
Stack Trace: As Microsoft.Win32.RegistryKey.Win32ErrorStatic(Int32 errorCode, String str)
As Microsoft.Win32.RegistryKey.OpenRemoteBaseKey(RegistryHive hKey, String machineName, RegistryView view)
As SnapManager.SMSCore.Host.Validations.DotNetVersionValidationActivity.IsValidDotNetVersionInstalled(SmHost windowsHost)
2021-06-22T22:47:53.6051049+08:00 ERROR SnapManagerWeb_71 PID=[6048] TID=[39] The network path was not found.
2021-06-22T22:47:53.6051049+08:00 ERROR SnapManagerWeb_71 PID=[6048] TID=[39] Failed to retrieve information about the installed package from the registry.
One of the reason for this failure could be:
The Run As Account does not have the access to the registry.
