跳转到主内容
适用于Oracle的SnapCenter插件备份失败、并且无法发现无法检索单元序列号的对象
6
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
  • 适用于Oracle的SnapCenter插件
问题描述
适用于Oracle的SnapCenter插件备份失败并显示错误
Failed on 'hostname': Activity 'Discovering File-System' failed with error: Discovery failed for object <directory> with error Failed to retrieve the unit serial number for the device '/dev/..', Reason: 'SCSI inquiry failed. Check if the disk.EnableUUID parameter is set to TRUE in the VM configuration file.'
New to NetApp?
