跳转到主内容
SnapCenter HA MySQL 复制失败,并出现超时错误
22
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
SnapCenter 4.3.1
问题描述
  • MySQL 复制的数据库运行状况不正常
  • Windows 应用程序事件日志出错:
Unable to rebuild database. ReplicationStatus : UnHealthyReplicationIssues : Replication of the repository failed with error: Error executing row event: 'Table'nsm.nsm_eumsession' doesn't exist'. You can manually correct the error or rebuild the repositoryon XX.XX.XX.XX by running the'Set-SmRepositoryConfig' cmdlet with the '-ServerToRebuild' option.
New to NetApp?
  • 这篇文章对您有帮助吗?
