SnapCenter 自定义插件备份在前一天成功运行后失败
适用场景
- SnapCenter自定义插件(SCC)
- 适用于Oracle的SnapCenter插件(SCO)
问题描述
- 每天SCC备份在前一天成功运行后失败。
- 如果 服务重新启动、则首次新备份将成功、但随后会失败
- 如果服务未重新启动、可能会出现以下错误:
SCC-00164: Application quiesce for the plug-in [DB] failed with exit code [1] and with error :sudo: sorry, you must have a tty to run sudoSCC-00161: Application unquiesce for the plug-in [DB] failed with exit code [1] and error :sudo: sorry, you must have a tty to run sudoSCC-00185: Cleanup for the plugin [DB] failed with the exit code [102] and error :
