跳转到主内容
SnapCenter 克隆生命周期作业失败 在静止数据库以进行备份时
117
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用于
  • SnapCenter Server 6.X [SC]
  • SnapCenter Plug-in for Microsoft SQL Server [SCSQL]
  • Windows Server 2019,2022
  • SQL Server(所有受支持的版本)
问题描述
  • SQL Server 数据库的 SnapCenter 克隆生命周期作业在备份作业"冻结数据库"活动期间失败。
  • SnapCenter 备份作业或克隆生命周期作业失败,错误如下:
Activity 'Freeze database(s)' failed with error: Resource (Hostname\\Instance_name\\Database_name) failed with error (Failed to backup database [Database_name]. Error: A system assertion check has failed. Check the SQL Server error log for details.)
  • 示例日志输出(SmSql 日志):
ERROR SmSql_67763 PID=[6660] TID=[86] An exception occurred while executing a Transact-SQL statement or batch.
ERROR SmSql_67763 PID=[6660] TID=[86] A system assertion check has failed. Check the SQL Server error log for details. Typically, an assertion failure is caused by a software bug or data corruption. To check for database corruption, consider running DBCC CHECKDB.
BACKUP DATABASE is terminating abnormally.
Database 'ODW' is not suspended for snapshot backup.
ERROR SmSql_67763 PID=[6660] TID=[35] Failed to backup database [Database_name]. Error: A system assertion check has failed. Check the SQL Server error log for details.
New to NetApp?
