跳转到主内容
SnapCenter 6.X 安装在前提条件验证时失败
30
Visibility:
Votes:
0
Category:
not set
Specialty:
snapx
Last Updated:
适用于
  • SnapCenter Server 6.0(SC 6.0)
  • SnapCenter Server 6.1(SC 6.1)
  • SnapCenter Plug-In for Windows(SCW)
  • SnapCenter Plug-In for SQL(SCSQL)
  • SnapCenter Plug-In for Exchange(SCE)
问题描述
  • 尝试安装或升级 SnapCenter 6.X 时会出现有关 .NET 8.0 Windows Server 的错误:
  • 或者,可能会出现以下消息之一
Microsoft .NET 8.0 - Windows Server Hosting -> IIS module is missing. Repair of Microsoft .NET 8.0.8 - Windows server hosting is required.
500 - Internal server error.
There is a problem with the resource you are looking for, and it cannot be displayed
  • SCW 插件升级或安装失败,出现一般错误(MSI 安装错误代码 1603)。
  • 错误记录在SnapCenter_Windows_Host_Plug-in_Install_XXXX.log中:
Engine: property 'ASP_NETCORE_VERSION' value now '9.x.x'
(CLR Action): Highest available runtime: v4.0.30319
(CLR Action): Trying to use highest runtime...
(CLR Action): Using highest version runtime...
(CLR Action): SWInstallerHelper.CheckForRollbackLogs: SETUP_ERROR: Failed Plugin: SnapCenter Plug-in for Microsoft Windows
(CLR Action): SWInstallerHelper.CheckForRollbackLogs: SETUP_ERROR: MSI Errorcode: 1603
  • SCSQL 插件升级或安装失败,出现一般错误(MSI 安装错误代码 1603)。
  • 错误记录在 SnapCenter_Windows_Host_Plug-in_Install_XXXX.log
1-13-2025[04:17:17 PM]: (CLR Action): Highest available runtime: v4.0.30319
1-13-2025[04:17:17 PM]: (CLR Action): Trying to use highest runtime...
1-13-2025[04:17:17 PM]: (CLR Action): Using highest version runtime...
1-13-2025[04:17:17 PM]: (CLR Action): SWInstallerHelper.CheckForRollbackLogs: SETUP_ERROR: Failed Plugin: SnapCenter Plug-in for Microsoft SQL Server
1-13-2025[04:17:17 PM]: (CLR Action): SWInstallerHelper.CheckForRollbackLogs: SETUP_ERROR: MSI Errorcode: 1603
  • SCE 插件升级或安装失败,并出现以下错误:
  • SnapCenter_Windows_Host_Plug-in_Install_<JobID>.log
(ISP Action): A program failed to start.\nTrying to start a program resulted in an error.\nProgram location: \nProgram: "vssproviders\navssprv.exe"\nCommand line: -r service -a ".\LocalSystem"\n\nGetLastError returned: 0.
(ISP Action): RegisterVSSProvider: Register VSS Provider Result (Post Config Validation): -2147024894 .
(ISP Action): LaunchProgram: LaunchApplication Program exit code: 2, Exit message: The system cannot find the file specified.
(ISP Action): RegisterVSSProvider: ERROR: Failed to Configure the VSS Provider
New to NetApp?
