SQL克隆作业失败、并显示"svm.unid"或"svm.name must be 쳡 릩"错误
- 140
- Visibility:
- Public
- Votes:
- 0
- Category:
- snapmanager-for-microsoft-sql-server
- Specialty:
- snapx
- Last Updated:
适用场景
- SnapCenter服务器(SC) 5.0、5.0P1和6.0
- 适用于Microsoft SQL Server (SCSQL) 5.0、5.0P1和6.0的SnapCenter插件
- 适用于VMware vSphere的SnapCenter插件(SCV) 5.0P3
- ONTAP 9.15.1P2
问题描述
- SnapCenter UI:
Activity (Cloning Resources) failed with error: Failed to clone resources, error isMount operation failed with error Failed to mount storage resource, error is Failed to add LUN mapping [400]: Either "svm.uuid" or "svm.name" must be provided.
- <JobID>_SMC.log <Date_Time>:
DEBUG SMCore_<JobID> PID=[xxxx] TID=[xx] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: [400]: Either "svm.uuid" or "svm.name" must be provided.
DEBUG SMCore_<JobID> PID=[xxxx] TID=[xx] No retry condition match found or max retry reached. Throwing error The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: [400]: Either "svm.uuid" or "svm.name" must be provided.
DEBUG SMCore_<JobID> PID=[xxxx] TID=[xx] --PSHelper::RunCommand
ERROR SMCore_<JobID> PID=[xxxx] TID=[xx] Message : Failed to add LUN mapping
