SMSQL无法通过"添加原始设备映射时出错"来验证备份
适用场景
- SnapManager for Microsoft SQL Server ( SMSQL ) 7.2.3
- 适用于Windows的SnapDrive (SCW) 7.1.5
- 原始设备映射(RDM)
问题描述
- SMSQL无法通过""验证备份
Failed to Map virtual disk: Error Adding Raw Device Mapping。 - 备份报告显示SMSQL无法挂载快照、并显示错误"
Failed to Map virtual disk: Error Adding Raw Device Mapping"。
示例:[<HOST>] Starting SDAPI mount snapshot...
[<HOST>] Preparing LUN '<PATH>', for SDAPI operation...
[<HOST>] Mounting snapshot: <SNAPSHOT>
[<HOST>] Snapshot mount failed.
[<HOST>] [SDAPI Communication Exception]: Failed to create disk in virtual machine, Failed to Map virtual disk: Error Adding Raw Device Mapping -GetLunInformation returned false-<LUN_SERIAL_NO><LUNID>.
[<HOST>] SDAPI failed to mount snapshot.
[<HOST>] Error Code: 0x80004005
Unspecified error
Snpdrvdbg.log显示""Failed to Map virtual disk: Error Adding Raw Device Mapping并显示错误代码0x80004005。
示例:
PID:<PID> TID:<TID> FCPVdisk.cpp@4091 CFCPVdisk::CreateRawDeviceMapping() Lun Path=<LUN_PATH> : FilerName:<VSERVER_NAME>
PID:<PID> TID:<TID> FCPVdisk.cpp@4093 CFCPVdisk::CreateRawDeviceMapping() Lun Serial No=<LUN_SERIAL_NO>
PID:<PID> TID:<TID> FCPVdisk.cpp@4095 CFCPVdisk::CreateRawDeviceMapping() DataStore name=<DATASTORE>
PID:<PID> TID:<TID> FCPVdisk.cpp@4121 Failed to Add the virtual Disk through raw device mapping, , error code: '0x80004005', error description: 'Failed to Map virtual disk: Error Adding Raw Device Mapping -GetLunInformation returned false-<LUN_SERIAL_NO><LUNID>'
PID:<PID> TID:<TID> localerror.cpp@82 Is_VDS_ITF_Error(): false.
PID:<PID> TID:<TID> localerror.cpp@94 Is_WMI_ITF_Error(): false.
PID:<PID> TID:<TID> FCPVdisk.cpp@4123 Failed to create disk in virtual machine, Failed to Map virtual disk: Error Adding Raw Device Mapping -GetLunInformation returned false-<LUN_SERIAL_NO><LUNID>.
HRESULT 0xc00403e3.
VirtualizationAPI.log显示""Error Adding Raw Device Mapping -GetLunInformation returned false。
示例:
VirtualizationAPILog Critical: 1 : <TIMESTAMP> PID:<PID> TID:<TID> @-1 Finish CEsxServer::GetLunInformation() returned False
VirtualizationAPILog Critical: 1 : <TIMESTAMP> PID:<PID> TID:<TID> @-1 CEsxServer::MapVirtualDisk() - GetLunInformation returned invalid entries:Lun Serial No:<LUN_SERIAL_NO>,LunID:<LUNID>
VirtualizationAPILog Critical: 1 : <TIMESTAMP> PID:<PID> TID:<TID> @-1 CEsxServer::MapVirtualDisk() - Name : Exception Message : Error Adding Raw Device Mapping -GetLunInformation returned false-<LUN_SERIAL_NO><LUNID> Trace : VirtualizationAPI.CEsxServer.MapVirtualDisk(String strLunSerialNo, UInt32 nLunId, String strDataStoreName, String strFilerName, UInt64 nSizeInKB, Boolean bRDMFileSpecified, String strRDMFileName, Boolean bShared, EnumAdapterType eAdapterType, String strInitiatorName, UInt32& nControllerKey)Datastore :<DATASTORE>
VirtualizationAPILog Critical: 1 : <TIMESTAMP> PID:<PID> TID:<TID> @-1 CVirtualServer::MapVirtualDisk() - Failed to Add virtual disk: Exception message: Error Adding Raw Device Mapping -GetLunInformation returned false-<LUN_SERIAL_NO><LUNID>
