跳转到主内容
适用于Linux的SC Server PowerShell cmdlet失败、并无法识别命令
适用场景
  • 适用于Linux的SnapCenter服务器
问题描述
尝试在适用于Linux的SnapCenter服务器上运行PowerShell cmdlet (例如 open-smconnection)时,失败,并显示:
The term 'command being ran' is not recognized as a name of a cmdlet, function, script file, or executable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
New to NetApp?
