跳转到主内容
SCW 无法使用 SMAPI 获取资源对象
38
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
适用于 Windows 的 SnapCenter 插件( SCW )
问题描述
  • 在适用于 Windows 的插件主机上执行刷新磁盘时未发现磁盘
  • 资源发现作业的scw_scale.log <JOB> 报告以下错误
Information SDW PID=[5152] TID=[22320] GetHostFileSystem: Return '0' lun fileSystems
Error SDW PID=[5152] TID=[22320] Failed to get resource object graphs using SMAPI. Error code: 0. Details: Failed to enumerate the disks.
Verbose SDW PID=[5152] TID=[22320] --SmapiToStorageResolver::GetResourceObjectGraphs
Verbose SDW PID=[5152] TID=[22320] ++VirtualDiskDiscoveryManager::ResolveVirtualDiskStorageLayout
Error SDW PID=[5152] TID=[22320] Error: The resource graph is null/empty
  • 或者、您可能会看到以下顺序和错误:
Verbose SDW PID=[3652] TID=[2096] query: select * from MSFT_Volume Where FileSystem = 'NTFS'
Verbose SDW PID=[3652] TID=[2096] scope: \\SRV00123\root\Microsoft\Windows\Storage
Verbose SDW PID=[3652] TID=[2096] ++ConfigManager::GetConfigSettingIs_Wmi_Timeout_Set
Verbose SDW PID=[3652] TID=[2096] INFO: Config setting for whether to do have WMI query time out is not found. Using the default value of False
Verbose SDW PID=[3652] TID=[2096] INFO: WMI query time out = False
Verbose SDW PID=[3652] TID=[2096] --ConfigManager::GetConfigSettingIs_Wmi_Timeout_Set
Information SDW PID=[3652] TID=[2096] Completed GetWindowsVolumes using select * from MSFT_Volume Where FileSystem = 'NTFS'
Error SDW PID=[3652] TID=[2096] Error: Failed to get Windows volumes
  • 第三、除了上述错误之外、WMI可能无法正确响应、进而导致以下输出:
Verbose SDW PID=[3652] TID=[2096] GetWindowsVolumes: Added 0 volumes
Verbose SDW PID=[3652] TID=[2096] --HostDiscoveryManager::GetWindowsVolumes
Verbose SDW PID=[3652] TID=[2096] GetHostFileSystem: Task threads completed
Verbose SDW PID=[3652] TID=[2096] GetHostFileSystem: Found 0 disks
Verbose SDW PID=[3652] TID=[2096] GetHostFileSystem: Found 0 partitions
Verbose SDW PID=[3652] TID=[2096] GetHostFileSystem: Found 0 hostVolumes
Verbose SDW PID=[3652] TID=[2096] ++HostDiscoveryHelper::GetHostFileSystemList
Verbose SDW PID=[3652] TID=[2096] INFO: SupportInstallableFileSystem flag not found.
Verbose SDW PID=[3652] TID=[2096] Return SupportInstallableFileSystem as true
Verbose SDW PID=[3652] TID=[2096] Support IFS
Verbose SDW PID=[3652] TID=[2096] --HostDiscoveryHelper::GetHostFileSystemList
Verbose SDW PID=[3652] TID=[2096] GetHostFileSystemList: Return 0 fileSystems
Verbose SDW PID=[3652] TID=[2096] GetHostFileSystem: Found 0 fileSystems
Verbose SDW PID=[3652] TID=[2096] --HostDiscoveryManager::GetHostFileSystem
Information SDW PID=[3652] TID=[2096] GetHostFileSystem: Total fileSystems: '0'
Information SDW PID=[3652] TID=[2096] GetHostFileSystem: Return '0' lun fileSystems
New to NetApp?
  • 这篇文章对您有帮助吗?
