跳转到主内容
选择控制阀升级到4.8无法升级网络运行时文件
123
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
适用于VMware vSphere的SnapCenter插件(SCV) 4.8
问题描述
  • 维护控制台中显示选择控制阀升级到4.8成功
  • 从4.7之前的版本升级(因为4.7已经有更新的网络)时,选择控制阀将投诉:
Failed to get protection services status from configuration service: Connection refused (Connection refused). Please make sure the protection services are up and running
  • 虽然daemon.log 会显示以下错误:
Jan 31 14:46:15 mbrscv systemd[1]: Starting protection rbac service...
Jan 31 14:46:15 mbrscv protectionservice-rbac[14936]: It was not possible to find any compatible framework version
Jan 31 14:46:15 mbrscv protectionservice-rbac[14936]: The framework 'Microsoft.NETCore.App', version '6.0.0' was not found.
Jan 31 14:46:15 mbrscv protectionservice-rbac[14936]:   - The following frameworks were found:
Jan 31 14:46:15 mbrscv protectionservice-rbac[14936]:     3.1.2 at [/usr/bin/dotnet/shared/Microsoft.NETCore.App]
Jan 31 14:46:15 mbrscv protectionservice-rbac[14936]: You can resolve the problem by installing the specified framework and/or SDK.
Jan 31 14:46:15 mbrscv protectionservice-rbac[14936]: The specified framework can be found at:
Jan 31 14:46:15 mbrscv protectionservice-rbac[14936]:   - https://aka.ms/dotnet-core-applaunch?framework=Microsoft.NETCore.App&framework_version=6.0.0&arch=x64&rid=debian.11-x64
Jan 31 14:46:30 mbrscv protectionservice-rbac[14926]: /
Jan 31 14:46:30 mbrscv systemd[1]: protectionservice-rbac.service: New main PID 14936 does not exist or is a zombie.
Jan 31 14:46:30 mbrscv systemd[1]: protectionservice-rbac.service: Failed with result 'protocol'.
  • 选择控制阀插件UI未填充,当尝试重新启动选择控制阀服务时,显示维护控制台错误:
Job for the protectionservice-rbac.service failed because the service did not take the steps required by its unit configuration.
A dependency job for the scvservice.service failed. See journalctl -xe for details.
A dependency job for the protectionservice-backup.service failed. See journalctl -xe for details.
A dependency job for the protectionservice-configuration.service failed. See journalctl -xe for details.
A dependency job for the protectionservice-job.service failed. See journalctl -xe for details.
A dependency job for the protectionservice-logger.service failed. See journalctl -xe for details.
A dependency job for the protectionservice-policy.service failed. See journalctl -xe for details.
A dependency job for the protectionservice-report.service failed. See journalctl -xe for details.
A dependency job for the protectionservice-resources.service failed. See journalctl -xe for details.
A dependency job for the protectionservice-scheduler.service failed. See journalctl -xe for details.
A dependency job for the protectionservice-storage.service failed. See journalctl -xe for details.
Failed to VMware plugin status: Connection refused (Connection refused). Please make sure the plugin is up and running. Failed to get protection services status from configuration service. Connection refused (Connection refused). Please make sure the protection services are up and running.
vCenter Plugin connection has failed. VADP Server error occurred
New to NetApp?
